by AA52 Investigator
Slow speed on Fiber Plus
I recently got EE Fibre plus with a min. 75mbps and max of 79 mbps and guaranteed 74mbps. I was very happy with the installation and enjoying the consistent good speed usally about 73.4 mbps. but after a week it dropped to 66mbps and I assumed it was due to the testing in the initial 10 days. but its been over 2 weeks now and it hasn't moved above 54-57mbps and is settled. the download sync on the router shows 60mbps, I don't know why... I had contacted EE after the 10 days and they logged in as a fault and couldn't find any fault on the line.
1. Router stats:Router stats.jpg
2. wired speed test results: https://www.thinkbroadband.com/speedtest/1549984591191243155
3. My local exhange:
https://availability.samknows.com/broadband/exchange/LWSHE
4. Bt Broadband Availability Checker:BT Broadband checker.jpg
Any help would be really appreciated.
Solution
Re: Slow speed on Fiber Plus
UPDATE: after the engineer checked the cabinet, after a couple of days the speed went up to 71.7 mbps which i was satisfied with but was still below min. guaranteed speed. So, EE sent out a specialist engineer who said there was a brtidge tap error(too many extension socket wires bundled together at the main socket entry line box), so he connected just one socket to the main line and configured it as the main socket and did a DLM reset and surprise. I'm at 80mbps. The EE support was excellent and very quick to send out the engineers and on top of that they compensated for the days I was below minimum speed.
6 REPLIES 6
What are all EE's contractual speed estimates given in your MyEE for BB under Your broadband speed ?
Broadband speed tells you how fast data is sent (upload speed) or received (download speed) along your phone line. It's measured in megabits a second (Mb/sec), usually shortened to Meg or Mb.
Minimum Fibre Download Speed is 75.0 Mb/Sec
Maximum Fibre Download Speed is 76.0 Mb/Sec
Minimum Fibre Upload Speed is 19.0 Mb/Sec
Maximum Fibre Upload Speed is 20.0 Mb/Sec
Minimum Guaranteed Download Speed is 74.0 Mb/Sec
You'll find more information in our guide about broadband speed.
To find out your actual broadband speed, you can run a speed test. You'll find more help with this in our guide to testing your broadband speed.
EE is a signatory to the Voluntary Broadband Speeds Code of Practice. This means that we will always aim to give our customers clear and accurate information on home broadband speeds.
You are actually getting 60 Meg, well below EE's Minimum Guaranteed Download Speed of 74 Meg. You should call EE to complain that they are not delivering their Guaranteed speed.
UPDATE: I had talked to EE and they sent out an engineer. He saw no fault with the router or wiring and told that he will check the cabinet. I will be notified by EE later regarding the outcome.
Solution
Fantastic to hear, @AA52.
I'm glad it's all sorted for you. 🙂
