by Meterman1968
Slow internet
I have just got new fiber optic broadband and it’s still as slow as the old internet ! Does it take a while before it gets up to speed ?
10 REPLIES 10
Re: Slow internet
@Meterman1968   It can take day or so, EE will be in touch to inform you of your speed in about a week. If it’s not right then do contact customer services.
Re: Slow internet
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
by robertdl Investigator
Re: Slow internet
how long u had it installed for
by Tamas001
New Member
Re: Slow internet
everything depends on your  guaranteed speed..... and yes the ee unfortunatley too slow and not reliable
Re: Slow internet
my speed if fine get my garenteed speed of just under 70mb
by Meterman1968
Re: Slow internet
Sent from my iPad
Re: Slow internet
Hi there @Tamas001
Thanks for coming here.
Are you experiencing slow speeds with your Home Broadband?
If so, can you let us know what is happening?
Re: Slow internet
Let us know how you get on @Meterman1968
Have a lovely Sunday 🙂
by Meterman1968
Re: Slow internet
Have done a factory reset and will see how things are
Sent from my iPhone
Re: Slow internet
