by allanb22 Investigator
Slow fibre broadband
I have fibre broadband but the speed has been down as low as 1mb.  The average seems to be about 5mb.  The upload seem to be OK and I often get about 8mb UP.
What can be done to get my speed close to the contracted 40mb?
The DSL status from my broadband router are:
Status
Configured
Current
Line Status
UP
Link Type
Fast Path
Operation Mode
Automatic
G.993.2 (VDSL2)
Data Rate Information
Upstream
9999 (Kbps)
Downstream
40000 (Kbps)
Defect/Failure Indication
Operation Data
Upstream
Noise Margin
13.8 (dB)
Line Attenuation
0.0 (dB)
Downstream
Noise Margin
14.2 (dB)
Line Attenuation
 16.3 (dB)
Indicator Name
Near End Indicator
Far End Indicator
Output Power  2.6 (dBm) 12.8 (dBm)
Fast Path FEC Correction 73922 7571
Interleaved Path FEC Correction -- --
Fast Path CRC Error 0 0
Interleaved Path CRC Error -- --
Loss of Signal Defect 1 0
Fast Path HEC Error STR 0 0
Interleaved Path HEC Error -- --
Error Seconds 10 1383
 Statistics
Received Data 8282895 (Kbits) Transmitted Data 15678121 (Kbits)
The link to a current speedtest is:
https://www.thinkbroadband.com/speedtest/1500021216133491355
and my exchange is:
https://availability.samknows.com/broadband/exchange/WWSPET
6 REPLIES 6
Re: Slow fibre broadband
@allanb22: What's the Uptime corresponding to those router stats?
Is that speedtest over wireless? If so, what's it like wired?
The speed was measured over an eithernet connection.
Can I get the uptime from the router it has not been powered off and on for some time?  The speed seems to vary according to the time of day, at about 5am I can get the full 38mb but in the morning and early evening it drops to 1-4mb.
Post 'System Uptime' from top of System Log page.
System Uptime is: 776:46:36
Can't see anything wrong there.
Does this slow down only occur during peak times?
Did you upgrade to fibre from ADSL with EE?
It depends what you call peak times.  It is currently 4.95 mbs at 3:15pm.  The slowdown is only affecting download speed; the upload speed is usually higher than download.  Upload is currently  9.2mbs!
Is my connection being throttled?
I did not upgrade from ADSL, I contracted fibre.
