by Yversongs
New Member
Slow connection speed
Been experiencing extremely slow internet connection speed where videos freezes for hours. I only a few months ago got told i was upgraded to a faster broadband speed. I pay more now doe this slow connection than i did in previous years. Please i woupd like this sorted as i am considering other options. Thank you.
Re: Slow connection speed
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
