Highlighted
by Investigator
Slow broadband
I have been experiencing very slow broadband speeds for over 2 weeks, dropping lots of times.
Untitled.pngCould someone help me with this matter please?
Thanks in advance.
Regards,
Pedro
Highlighted
Re: Slow broadband
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
Highlighted
by Investigator
Re: Slow broadband
Thank you for your reply.
Here it is the results:
Router Stats:
Line Status:Connected
DSL Modulation Type:ADSL_2plus
Annex Type:Annex A
wired speedtest:
https://www.thinkbroadband.com/speedtest/1525186157267334055
Exchange:
https://availability.samknows.com/broadband/exchange/LWKGRE
Thank you.
Highlighted
Re: Slow broadband
Well, there's nowt wrong there. Your BB connection is good & the speed test is commensurate with that.
Highlighted
by Investigator
Re: Slow broadband
Thank you for your fast reply.
Actually it looks better now, it has been terrrible for the past 2 weeks, hopefully it will keep like that .
Thank you
Highlighted
Re: Slow broadband
Let us know how you get on @curioso
Have a lovely evening 🙂
