by williamg97
Slow broadband speed - Help plz
Hi all,
Appreciate some help on this please. We've had EE / Orange broadband here for about 2 years and since I remember the broadband speed is very slow.
From looking at speed tests it's the upload speed that's the reason behind it.
I'm currently getting 575 Kbps upstream and 12815 Kbps downstream.
Thank you all.
Please see all statistics below:
1. Full router stats:
System Uptime is: 1321:37:38
STATUS   Configured Current Line Status -- UP Link Type -- Fast Path Operation Mode Automatic G.992.5 (ADSL2+)
DATA RATE INFORMATION Upstream 575 (Kbps) Downstream 12815 (Kbps)
DEFECT/FAILURE INDICATION Operation Data Upstream Downstream Noise Margin14.6 (dB) 7.7 (dB) Line Attenuation 16.7 (dB) 31.0 (dB)
Indicator Name Near End Indicator Far End Indicator Output Power 12.8 (dBm) 0.0 (dBm) Fast Path FEC Correction 0 0 Interleaved Path FEC Correction -- -- Fast Path CRC Error 0 0Interleaved Path CRC Error -- -- Loss Of Signal Defect 2 0 Fast Path HEC Error STR 178222432 Interleaved Path HEC Error -- -- Error Seconds 24388 490
STATISTICS Received Data 34359738 (Kbits) Transmitted Data 2147408 (Kbits)
2. Speed Test Results
https://www.thinkbroadband.com/speedtest/1505060273796008055
3. Exchange
https://availability.samknows.com/broadband/exchange/SLDF
4. BT broadband availability checker
Telephone Number 123 on Exchange DRONFIELD is served by Cabinet 27
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  High Low High Low         VDSL Range A (Clean) 15.5 9.5 1.2 0.8 7.9 Available -- -- Yes --VDSL Range B (Impacted) 10.8 3.6 1.2 0.6 2 Available -- -- Yes --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
        FTTP on Demand 330 30 -- Available -- -- -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 7 -- 4.5 to 11.5 Available -- -- -- -- WBC ADSL 2+ Annex M Up to 7 Up to 1 4.5 to 11.5 Available -- -- -- -- ADSL Max Up to 5.5 -- 4 to 8 Available -- -- -- -- WBC Fixed Rate 2 -- -- Available -- -- -- -- Fixed Rate 2 -- -- Available -- -- -- --
Other Offerings
Availability Date
        VDSL Multicast -- -- -- Available -- -- -- -- ADSL Multicast -- -- -- Available -- -- -- --
Premise environment
Status
Bridge Tap U               VRI N               NTEFaceplate N               Last Test Date 19-05-2017
Re: Slow broadband speed - Help plz
There's nowt obviously wrong with your BB other than the slow upstream.
Try rebooting the router once & then reposting full router stats. Don't do this too often.
