by ciscosurplus
Slow IP Profile
Hi, steadily over 18 months my sync speed and IP profile has dropped. Initially I was getting 80/20 full sync and 75 on BT download test.
fast forward and my sync speed on the router is 63/20. But download speed test are 50. According to BTW my ip profile is set to 51.
According to BT wholesales availability checker I get the following;
VDSL Range A (Clean)8070.9201965.4AvailableAvailable--
VDSL Range B (Impacted)8068.6201962.6AvailableAvailable--
If I go to order broadband I get a min guaranteed speed of 63?
FAQ
Results Image not loaded
1. Downstream Test: -provides background information.
 Download Speed
 51.76 Mbps
0 Mbps51.6 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 51.76 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-51.6 Mbps .
 Additional Information:
 IP Profile for your line is - 51.6 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 12.35 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 12.35Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
Houses on both sides and opposite get a full 80/20 as cabinet is just round the corner. Any ideas what to do next?
by Ace Contributor
Re: Slow IP Profile
Hi @ciscosurplus
im afraid I can’t help with this particular issue but I’m sure @XRaySpeX   could help.
Re: Slow IP Profile
You can't trust the BT Speedchecker. How can Achieved Speed 51.76 Meg be > Max Achievable Speed 51.6 Meg?
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
Re: Slow IP Profile
@ciscosurplus
Do you use the supplied router or have you tried a third party one?
by ciscosurplus
Re: Slow IP Profile
1. Im not using the EE box as it broke I have a Vigor130 modem and an ASUSAC5300
From the modem (this is 72 hours uptime as had a power cut)
  ---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) -----------
   Running Mode            :      17A       State                : SHOWTIME
   DS Actual Rate          : 59486000 bps   US Actual Rate       : 19554000 bps
   DS Attainable Rate      : 6909460 bps   US Attainable Rate   : 19558000 bps
   DS Path Mode            :        Fast    US Path Mode         :        Fast
   DS Interleave Depth     :        1       US Interleave Depth  :        1
   NE Current Attenuation  :       11 dB    Cur SNR Margin       :        9  dB
   DS actual PSD           :     0. 0 dB    US actual PSD        :    12. 5  dB
   NE CRC Count            :        7       FE CRC Count         :     9610
   NE ES Count             :        3       FE  ES Count         :     8453
   Xdsl Reset Times        :        0       Xdsl Link  Times     :        1
   ITU Version[0]          : fe004452       ITU Version[1]       : 41590000
   VDSL Firmware Version   : 05-07-06-0D-01-07   [with Vectoring support]
   Power Management Mode   : DSL_G997_PMS_L0
   Test Mode               : DISABLE
  -------------------------------- ATU-C Info ---------------------------------
   Far Current Attenuation :       13 dB    Far SNR Margin       :        5  dB
   CO ITU Version[0]       : b5004244       CO ITU Version[1]    : 434da48c
   DSLAM CHIPSET VENDOR    : < BDCM >
2. Link to results from a wired test on iMac 5K 1gb ethernet directly.
https://www.thinkbroadband.com/speedtest/1559486865143370455
3. Connected to Longworth exchange - https://availability.samknows.com/broadband/exchange/SMLW
Re: Slow IP Profile
You're only getting 59.5 Meg sync. It could be due to cross talk as more neighbours join your cab. Are you sure the neighbours you quoted as getting 80/20 Meg are on the same cab & are actually getting that or is that just the BTw estimates for them as it is for you?
What did EE quote as your Guaranteed Min Speed when you joined up? You'll find this in your MyEE for BB.
