by morrissey2020 Contributor
Second thoughts
I must admit that after two days with EE broadband I’m really regretting my decision. The Wi-fi signal is pitiful and I’ve had to restart the router several times already. There’s dead spots in the house (even within sight of the Bright Box), the TV box is next to useless as I’m constantly having to reboot it or power it down when it freezes, unless of course it just switches itself off and the TV app is hit and miss whether it works unless I’m sitting on the router. I’m assuming that the equipment will need replacing but I can’t really face hanging on a phone for an hour so it’s just tough. Anyway, the BT home hub will be coming out tomorrow and the TV box is going to be disconnected so we’ll have to do with free view for a while. I’m totally disappointed.
12 REPLIES 12
by Skilled Contributor
Skilled Contributor
Re: Second thoughts
Why do you have a BT Home hub connected to anything ? This will cause all sorts of problems if connecyed to the same circuit as the Brightbox.
Re: Second thoughts
If you would like help with your speed or connection issues, please would you carry out the steps and provide the data as requested in the Need Help with Your Home Broadband Speed or Connection? sticky. This will enable us to diagnose the problem and advise you further.
Re: Second thoughts
I haven’t got my home hub connected to anything at the moment; I’m purely using EE hardware. I’d just like to get some Wi-fi that’s usable and I think adding a router as a Wi-fi extender is the only way.
Re: Second thoughts
Hi @morrissey2020,
Welcome to the EE Community.
Have you tried changing the WiFi channel?
Are you connecting via 2.4GHz or 5GHz? (You might find using 2.4GHz improves the WiFi range)
Do you experience the same issues when using a wired connection?
Re: Second thoughts
Final straws:
Had to power up the TV box four times yesterday. It just stalls or switches itself off.
This morning once again the WiFi has disconnected from our devices so have done the daily reset at the router.
And I can’t talk to anyone because the phones are down.
Goodbye EE, I’m just checking my T&Cs to get out of this awful experience.
by Brilliant Contributor
Re: Second thoughts
You should have a 14 day cooling off period to cancel if needed.
Re: Second thoughts
From sign-up not going live.
Re: Second thoughts
How do you know it’s going to be awful until you go live though?
Re: Second thoughts
You don't but this is the supply of services, not goods.
Re: Second thoughts
So what happens when both goods and services turn out to be sub standard?
It’s not good enough and I will be terminating my contract.
Once I get through on the phone that is!
Re: Second thoughts
@morrissey2020: Sorry, I stand corrected. I was going by an older T&Cs, not realising EE had brought out a more consumer-friendly one about 3 months ago.
As long as you ordered your BB by phone or online, not thro' an EE shop, you may cancel FoC within 14 days of your actual activation date.
Re: Second thoughts
Great, thanks
