by patgfitz
Router
Should I have been sent a new router when I upgraded my broadband? My router needs constantly reset as it's 4 years old
Re: Router
Hi @patgfitz
Give EE a call and let them know your current router is faulty.
Re: Router
Not necessariily if you are on the same type of BB. What product did you upgrade to & which router do you have?
by patgfitz
Re: Router
I have the brightbox. I upgraded from fibre to fibre plus. Never seem to
get more than 30mb/s though.
Re: Router
Then you don't need a new router just due to the upgrade. The Brightbox 2 works on both packages. That's why they never sent you one.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
