by Mason1234
Replacement Router
So I have contacted EE due to an issue with my broadband. An engineer came out and found the fault, he said that it was the router and a faulty line. He has fixed the line but still the router is still not working to it’s full potential. So the engineer told me to contact EE about a new router. I contacted EE Broadband Services. They have ordered me a new router and it should be here in 2 days. What I would like to know is I’m on a Fibre Plan at the moment. I’ve had that plan for 2 years and have renewed it a couple of months back and kept the router, but now as the problem has started I now need a new router. Will I get the same router as I have which is the Brightbox 2 or will i get the new Smart Hub. I thought this because I’m on a fibre plan and you get the smart hub when you choose a Fibre plan. So will I get the the same router as I have now which is the Brightbox 2 or will I get the new Smart Hub?
Re: Replacement Router
Hi there @Mason1234
If you give our broadband team a call on 0800 079 8586, they will check your account and see what router has been ordered.
Leanne 🙂
You will probably get a Smart Hub but you don't really know whether your current router is faulty & that a new 1 will fix your issues.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
