by sgfx
Reduced Speed & High Ping
I logged onto my PC a couple of days ago and found out that my connection had randomly decreased and my ping in game went from its usual "17" to "300+". Then I have been troubleshooting for the past few days, I have re-plugged all cables, set router to factory settings and it didn't fix anything. Someone please help I have run speedtests and I am getting around 277 ping and 26 download and 4.4 upload.
by sgfx
Reduced Speed and High Ping
by sgfx
Re: Reduced Speed & High Ping
Product name,EE Smart Hub
Serial number,+EEH001+1835001682
Firmware version,v0.00.24.06190-EE (Tue Jun 19 17:25:19 2018)
Board version,01
Data sent / received,976.5 MB / 472.1 MB
DSL uptime,0 days 0 Hours 28 Mins 31 Secs
Data rate,5.05 Mbps/39.99 Mbps
Maximum Data rate,5.0 Mbps/45.7 Mbps
Noise margin (up/down),6.1/8.9
Line attenuation (up/down),34.2/21.8
Signal attenuation (up/down),33.6/19.1
Broadband username,PRODUCTIONHQNUN381816397@fs
2.4 GHz wireless network name,EE-Hub-52Dn
2.4 GHz wireless channel,Smart (Channel 6)
5 GHz wireless network name,5GHz-EE-Hub-52Dn
5 GHz wireless channel,Smart (Channel 44)
Wireless Security,WPA
Wireless mode,Mode 1
Firewall,Disabled
MAC address,4C:1B:86:A0:5E:EF
Software variant,-
Boot loader, 0.0.3-EE (Mon Dec 4 17:32:53 2017)
by sgfx
Re: Reduced Speed and High Ping
Board version,01
Firewall,Disabled
Software variant,-
1. Try a wired speedtest, using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
2. What exchange are you connected to? If you don't know use: http://www.samknows.com/broadband/exchange_search and post the URL of your exchange page.
3. Do a tracert to your game server & also to BBC.co.uk .
Recent solutions
