by Marcus63
Red light on router
Despite turning in and off and hitting the factory reset my router lights still turn red.
Re: Red light on router
Hi @Marcus63.
Welcome to the community.
When you did the factory reset, did you hold the pin reset button for 20 seconds?
Have a look at our What Do The Lights Mean On A SmartHub page.
Jon
by Marcus63
Thanks Jon, I have just tried to 20 second hold and received the same
outcome, still seeing the red lights.
Regards
Marcus
Thanks for trying, @Marcus63.
The next step would be to contact our Broadband Care team to check your account.
They will be able to help you to find the cause of the red light.
Jon
