13-05-2022 06:55 PM
quick question, if I opt for broadband without a phone line, will I still be able to recieve incoming phone calls through the landline phone? I know some people have a set up like this but wanted to be sure.
And I'm referring to the Phone Line not Line Rental.
13-05-2022 07:01 PM
@MrL92 : No, with EE BB w/out landline you get no voice service at all, not even for emergency services. You get no landline no. able to be called & no dial-tone.
13-05-2022 07:01 PM
13-05-2022 10:43 PM
@MrL92 if this is something that is important to you, then porting your number to a VoIP provider and adding a suitable VoIP phone solution would provide a way of doing so.
However doing so requires a fair amount of planning and organisation - much will depend on what you are trying to achieve.
