by Houldcroft Investigator
Recently got EE Broadband at 5ghz. Recommend an Alexa smart plug that works?
Having troubles getting a smart plug that works for Alexa and will work on EE 5ghz broadband . Any recommendations??
Re: Recently got EE Broadband at 5ghz. Recommend an Alexa smart plug that works?
Routers that do 5GHz also do 2.4GHz. If you have an EE Smart Hub try separating the wireless channels. On the Advanced / Wireless Settings page of the SH there is a button near the top to Separate the Bands. Turn it ON. Then the 5GHz SSID will appear starting with "5GHz-" & the 2.4 GHz SSID not starting with "5GHz-". Then connect the smart plug to the 2.4 GHz SSID if it can't do 5GHz.
Hi @Houldcroft
Just use the 2.4 channel. I use Tp-link HS110 plugs with power monitoring. They work just great with Alexa.
I think I have the EEsmart hub router- but where can I find the necessary
settings? There doesn’t seem to be anything on the actual router itself.
It’s just sitting there happily in it’s aqua lights.
*Pat Houldcroft*
Nothing on the router to change it to 2.4! Do I need a special app or
something.
*Pat Houldcroft*
Hi @Houldcroft,
Welcome to the EE Community.
You can log in to your router at 192.168.1.254. From there, please follow @XRaySpeX's instructions above.
