by Sadaf Investigator
Re: Why do I have little no coverage! Plus my broadband with you is slow too!
Fixed broadband
@Sadaf : I'll deal with your BB issue separately.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
