by 1000green Established Contributor
Re: New EE fibre internet and its intermittent?
I’ve been on max fibre 2 for nearly a month and it’s still a 10 pint than normal? Can you help me with this?
Re: New EE fibre Max internet and its intermittent?
@1000green : "10 pint"?
1. Try a wired speedtest, using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
2. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
