by 1000green Established Contributor
Re: I want to use my own router on fibre
Is this for Gfast too? I can't get my tplink router to connect Thanks
7 REPLIES 7
@1000green : Probably only BB Username & pwd, Auth method, PPPoE & MTU for G.Fast. All the rest will be in G.Fast modem.
What about vlan?
@1000green : Well, if the router has a slot for it, fill it in.
I thought you said in your other thread that you got it working with your Netgear, just that it was slow?
I have a better tplink router the archer VR2800 Its a powerful router. It says to use it vlan but when I use 101 it doesn't works
@1000green : Well, reading the Manual for your new router I see this:
 which defaults to the VLAN ID = 101.
Thats for DSL connection. I have to use a modem.
https://ibb.co/VD3xkbR Pppoe
I presume that you have tried enabling VLAN ID with the value 101 on that Ethernet page?
