by Marcusengland Investigator
Re: How to Increase upload speed
89D7EF3D-56C7-4D74-9B1C-C4E50A326478.pngExchange is andover 900m away
is it safe for me to copy and sent onto this post my router settings ?
15 REPLIES 15
Re: upload speed
Very worried about changing settings in my brightbox 2 router but I have to improve the upload speed. Currently 12 mbps download but only 0.8 mbps upload. I am looking to use WiFi blink outside cameras and the spec says min of 2 mbps upload needed. Any. Advice will be appreciated thanks.
Re: upload speed
Hi @Marcusengland
Once @XRaySpeX is online, I'm sure he'll be able to offer some advice on this.
If you'd like to speak to someone in the mean time, we have a technical support team that will do their best to help too.
Yes. @Marcusengland, there's no personal info in it. Everybody else does on sites all over the world. Make sure it is the router Status, not the router Settings.
Thanks for the info I will take a couple of pictures of the screens and post them when I get home. Regards marcus
Sent from my iPhone
Copy & paste would be quicker. Images take time to be approved.
@Marcusengland   Providing you’ve not got a broadband issue you cannot increase your upload speed.   The only way you can do this is to pay to have fibre installed to your home directly from the box in the street and that’s £££ and your monthly bill wil be £££.
@Marcusengland: Please post your full router stats. For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page. Full router stats are key to any speed & connection issues.
And the time connected is 175:07:47 I think you have the speed test results from this morning
Regards marcus
Sent from my iPhone
Yes, it's your router stats that are important in this instance. I'll be able to comment when I can see them once they're approved by the Mods.
@Christopher_G: These images seem to be taking a long time to appear. Or have they been removed?
Hi @Marcusengland and @XRaySpeX,
I'm afraid the images were rejected as they included personal information. (email/login details)
Please resubmit the images with any personal details removed.
@Marcusengland: The page I am after contains absolutely no personal info. You must have posted the Settings page (which does) but I only want the current DSL Status page.
After logging in navigate the exact path Advanced Settings/ Accept/ System/ DSL Status. Also post 'System Uptime' from top of System Log page. Full router stats are key to any speed & connection issues.
by Ace Contributor
Hello @Marcusengland have you spoken to customer service about your upload speeds? They can access your account to check for any issues. EE BB freephone customer service is 0800 079 8586 option 3.
