Highlighted
by Investigator
Re: EE smart hub restarting
I have the same problem  started yesterday. I am running on standard broadband with a fiber router.  After going through 4 Bright? Boxes in one year, I said a fiber router or I am leaving. First time it has gone wrong in 2 years.
Looks to me like its dying on me, hope I don't need to threaten to move if they don't replace it again!
Highlighted
@GarethA : Welcome to EE's Home Broadband Forum.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
Recent solutions
