by Colinw
Re: EE broadband transfer - BT say my landline is not recognised
I've had a similar issue moving from Talktalk to EE for fibre bb and landline. Been trying for last 6 wweeks for them to port my previous landline number and have had 3 dates from them of when it will be done,  the last being on friday. its still not been done and only just been told today they can't because talktalk own the number when talktalk have told me they've released the number and did it on the date if the transfer to EE but EE have given me a new number! To say I'm not happy is an understatement!
EE broadband transfer - EE Won't Port my TalkTalk Landline
@Colinw: EE seem to do this quite often. It saves them having to wait while TT write to you to tell you another provider is taking over your landline & giving you 2 weeks to reject it, as per OFCOM regs to prevent "slamming". That way EE gets you on-board sooner as a customer.
You are entitled to retain your landline no.  I should keep on at EE to port it over. They have done this before & eventually brought the right no. across.
Is your BB with EE up & running?
by Colinw
Re: EE broadband transfer - EE Won't Port my TalkTalk Landline
Hi
yes it is but for fibre is much slower than i had with talktalk which wasn't fibre! they've said it's a fault on the line.. have checked it and now have an engineer booked to come out!
Sent from my Samsung Galaxy smartphone.
If you would like help with your speed or connection issues, please would you carry out the steps and provide the data as requested in the Need Help with Your Home Broadband Speed or Connection? sticky. This will enable us to diagnose the problem and advise you further.
