Highlighted
by Investigator
Re: Can you unblock TCP Port 445 on my home broadband account?
yes, they are blocking port 445
as specified in traffic management rules
(For the techies amongst you we stop connections to non-EE SMTP servers on
port 25, and block NetBIOS)
EE, please unblock
16 REPLIES 16
Highlighted
@paganiniv: That's an old TM KFI, Feb 2014. The latest, July 2017, can be found at EE Broadband Traffic Management Policy .
EE block no ports:
Are any services, content, applications or protocols blocked on this product?**
No
Nowt to unblock! This issue is all Win 10's doing.
Highlighted
by Investigator
its definitelly blocked
I have several linux machines at different places to test it out
I have
Product name -  Smart Hub
Firmware version:v0.00.24.06190-EE
tried to disable firewall on the router as well
Highlighted
@paganiniv~: What are you actually trying to that uses port 445?
Highlighted
by Skilled Contributor
Skilled Contributor
I have
If the devices are on your local network, then EE would not block access and this is a local configuration issue.
if you have a switch, then setup one pc to provide dhcp/dns and test without the router connected. You could even test locally by pulling out the internet connection and testing. If the router detects that the address you are sending to is on your internal network it will not reroute to the internet.
If you are connecting to devices at different locations, then yes EE can/may/will block ports and best solution is to use VPN or change the ports on the devices itself.
Highlighted
by Investigator
I need to connect to Azure storage and simular services over the internet
port 445 is definitelly blocked on EE side
Highlighted
Skilled Contributor
have you actually performed a google search
Google Is Your Friend
or
Connect to Azure with port 445 blocked
Highlighted
by Investigator
yes, I have
do you understand the difference between syncing and mapping a network drive?
Highlighted
Skilled Contributor
@paganiniv wrote:
yes, I have
yes i do,
but in your posts you don't mention you specifically want to map a drive or that you need to map a drive.
if you've got linux servers configured on your network, you could try the following (last post) which is also found on the internet.
Mapping Azure Fileshare with port 445 blocked
Highlighted
by Investigator
I know how to make it complicated way, but I needed a simple and cheep solution
which did not work as expected and the fact that everyone on the forum was saying that EE is not blocking anything made it even more complicated to troubleshoot
so I had to spend whole evening to prove that EE is actually blocking port 445
Highlighted
@paganiniv: Where are these Azure storage and similar services located? On your own LAN? If so, how are they connected to your LAN?
Highlighted
by Investigator
"Microsoft Azure is a cloud computing service"
its not located on my LAN obviously
Highlighted
Skilled Contributor
the OP was on about lan side, you've highjacked the thread with a different scenario - on the OP issues the information provided was correct that EE do not block ports on your local LAN.
You have posted on the thread that you are using a remote connection and thus which I've stated further up in this thread is the EE can/may/will block this port, this goes for most of the ISP's out there as this port is vunerable. If you really need to use this port then you really need a business ISP that will allow use of port 445, which ISP allows for this I'm unsure, but you won't be able to access this port on 99.99%-100% of consumer ISP's.
Highlighted
I agree! This has become confusing. In fact the other OP thought the issue was on the WAN but it turned out to be a Win 10 issue on his LAN.
However I don't see how you can claim:
How can you claim that EE "can/may/will" block port 445 when they now declare that they now block no ports whatsoever? Yes, over a year ago they did block port 445 along with SMTP port 25 but now it is easily tested that port 25 is not blocked. Any PC email client can do a send on port 25 wherever the mail provider allows it. Why should it be any diff for port 445?
Highlighted
Skilled Contributor
port 445 is different to port 25 and is more of a security issue so isp's will more or less block it to prevent ransomware like wannacry and it's derivatives which are easily spread across network drives of which port 445 is used for.
So the ISP is correct in blocking this ports to ensure security of it's systems as well as it's customers.
Highlighted
by Investigator
I need to do exactely the same thing with my Azure Fileshare, it's really off-pissing.
Highlighted
@tgp1987: What OS are you running? If it is Win 10, I suggest you enable SMB 1.0/CIFS File Sharing Support in Windows Features. Win 10 started disabling this sometime in its life.
Recent solutions
