by Henny89
Re: Can't connect my "Entertainment Box" (Droid Box) to router?
Hi
I have a similar issue, my smart tv box was always previously connected by Ethernet to my previous TalkTalk router now I have my new EE router it disconnects after two minutes of connection and its ethernet?
any ideas???
@Henny89 : Is the TV now connected to the EE router by WiFi? What router is it?
by Henny89
Hi
Thank you for the reply.
The smart TV box only works on wifi, but when its ethernet it disconnects after a minute or so and cannot reconnect.
I prefer ethernet connection like I had before.
I have the EE Smart Hub.
Hi @Henny89
Welcome to the community.
Have you spoken to our Tech Gurus? They'll be able to run through some troubleshooting with you.
