by sparkman999 Investigator
Re: Broadband Activation
Hi All
I am new to EE and have just had Fibre Max 1 Broadband installed 5 days in I have carried out a speed test from my iPad see below I have been promised 145 it’s still in settling mode first day I had 149mb but as you can see it seems to have dropped to 130ish previously I was getting a solid 75mb with plusnet will update at 10days to compare speed
https://www.thinkbroadband.com/speedtest/1536077779650518155
6 REPLIES 6
It should stabilise soon for you, @sparkman999,
Keep us updated. 🙂
@sparkman999: All speed estimates from ISPs & BT are of sync speed as measured by the modem, not of speedtest throughput speed which will be a bit lower. With G-Fast that you have using a BT locked modem we can't know its sync speeds.
What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
What are all the speed figures quoted by EE in your MyEE for BB under Your broadband speed ?
The 10-day learning period is a bit of an urban myth. The DLM is running all the time on your line giving you the fastest stable speed at the time.
Screen Shot 2018-09-06 at 15.47.22.pngScreen Shot 2018-09-06 at 15.48.29.png
From EE
Minimum Fibre Download Speed is 84.20 Mb/Sec
Maximum Fibre Download Speed is 150.00 Mb/Sec
Minimum Fibre Upload Speed is 6.9 Mb/Sec
Maximum Fibre Upload Speed is 24.4 Mb/Sec
Minimum Guaranteed Download Speed is 76.30 Mb/Sec
You are probably getting about 137 Meg Down sync speed, well above EE's Minimum Guaranteed Speed & not far off the Max. Speed.
Thanks X-ray it does fluctuate throughout the day
but is an improvement
Thanks! You're welcome :)! Glad I could be of assistance.
137 Meg is not to be sneezed at on a 150 Meg product.
