by Dgarey Investigator
Re: Problems with sky q broadband connectivity
High do you enter all of the numbers for the google dns?
by Russo109 Contributor
The easiest way to go it is on your sky box. Go to settings network Change to manual and enter 8 8 8 8 for DNs. And restart box
No, you change the DNS in the router by switching it from "Obtain from ISP" to "Manual" in Basic Settings & the key in the pairs of nos. I gave you of whichever DNS you want.
by NeilCrompton Investigator
I have a Sky q box and a n EE4G router. The box is connected to the router but not to the Internet.
I line with your advice, I tried manually switching on the Sky Q box to a public DNS. This has had some effect in that it is now flashing backwards and forwards between connected to the internet and not connected. Does this mean I have not yet find the right public DNS address or is it possible that the Sky Q box is synching to my internet.
Thanks. I am having the usual problem of Sky telling me the problem is with EE and EE telling me the problem is with Sky.
In line with your advice, I tried manually switching on the Sky Q box to a public DNS. This has had some effect in that it is now flashing backwards and forwards between connected to the internet and not connected. Does this mean I have not yet find the right public DNS address or is it possible that the Sky Q box is synching to my internet.
Hi @NeilCrompton
Welcome to the community. 🙂
Unless @XRaySpeX has any other advice, I can only recommend speaking with our technical support team again for them to look into this further.
Have you set the DNS on the sky box and the minis to manual and 9999?
Also you need to restart the boxes after changing the settings.
Just for info after the last few firmware updates on sky q I'm not back to normal with DNs set to auto
Tried that thanks but no joy. It still says connected to the router but not to the internet. My son has similar problems with his x-box. He can connect to x-box live but not play a game online. All the other devices work fine. EE technical are supposed to be calling me back but have not. It is a very disappointing. It is an expensive service that does not work. Before I took out the contract to check that I could use both Sky Q and X box with EE4 g. Can anyone help?
EE Employee
Hi @NeilCrompton and welcome to the community.
Just so we can rule out any issues, please can we get you to try and connect your devices to your phone via tethering, this way we can rule out if its the device or connection.
Many thanks,
Lee
