by 133 Investigator
Ports aren't opening
i am trying to open ports and it's just not working, tried almost everything i possibly could, trying to do both protocols, tried to type device IP and just choose it, still nothing. any help with this? (i have smart hub)
9 REPLIES 9
Re: Ports aren't opening
Hi @133
Are you saving any changes you make?
@XRaySpeX  is our resident EE broadband user, so he should be able to offer some help.
@133 : What device is being port forwarded? Is it up?
Can you see your device over your own LAN using its internal IP addy?
What does ShieldsUP! report the status of your server's ports when you use its User-Specified Custom Port Probe ?
by 133 Investigator
My personal computer, yes it is. Yes, I can. And when I've checked port that i've forwarded (I've applied it to my device too) it says "Passed,  0 ports open, 0 ports closed, 1 port stealth"
OK, what is the server on your PC that you are trying open ports? Is that server up?
by 133 Investigator
It's a game server, yes it was up several times. I could join the game by using localhost as the IP, but using my public ipv4 adress didn't work, even my friends did try this.
You sure you, & they, are addressing it by the correct public IP at the time? You do know that it's liable to change at any resync? Still, Shieldsup! was using the correct 1.
Can you post an image of your Port Forwarding page?
by 133 Investigator
Hi there @133
Thanks for posting the image.
@XRaySpeX, is this what you needed?
by 133 Investigator
still got that issue.
