by stuey762
New Member
Port forwarding/ opening bright box 2
I have been trying to port forward on port 25565, i have followed every tutorial and every guide I have been able to find and I am unable to get the port to open, I have checked with several port checkers and they all keep showing the port as closed.
I have double and triple checked the settings are correct but to no avail, advice please?
Re: Port forwarding/ opening bright box 2
Have you reserved the IP of the service you are trying to port forward in the DHCP?
Is the service up & running? What is it exactly?
Please supply the Port Forward settings you have used?
