by justinvikki
New Member
Poor/intermittent home broadband speeds
We have for months been experiencing broadband speeds which are all over the place.
One minute the speeds are ok (10+mbps) and the next very low (sub3 mbps) When we first signed up for the service the speeds were steady but now we all find ourselves having to switch to 4G on our devices just to view pages which is of course a huge drain on our personal data allowances.
Do you know if EE have an email address or chat app where I might actually be able to speak to someone directly about this issue?
Many thanks.
Re: Poor/intermittent home broadband speeds
EE provides no email contact & I think Live Chat is only for mobiles.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
