by johnpatrick47
Poor Wi-Fi signal
I had fibre broadband connected at the beginning of April and everything is okay apart from the Wi-Fi signal strength in a couple of my ground floor rooms. I was previously with Sky and did not have this problem.
Any ideas on how to solve this.
Thanks.
Re: Poor Wi-Fi signal
@johnpatrick47  You could be getting interference on the router if it's close to a TV or other electronic items your home have you tried moving the router?   You could always purchase a wifi repeater to get better signals where there is a poor wifi reception.
1. Post your full router stats. For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page. Full router stats are key to any speed & connection issues.
2. Try both a wired & a wireless speedtest here http://www.thinkbroadband.com/speedtest.html and copy to here just the "Link to this result:" link.
Hi @johnpatrick47,
Thanks for joining the EE Community. Smiley Happy
Have you tried changing the wireless channel on your Bright Box?
