by kcred2
Poor WIFI strength around house
Hi, I just moved to ee and have probably a silly question.
The WIFI signal is really poor in my son's room (attic) and I'm wondering if there's anything either I or ee can do about that? Do I need a booster box or something?
Thanks!
Re: Poor WIFI strength around house
Try changing the WiFi band as it may help.
As for extenders, yes if your signal is weak they may help. Alternatively use powerline adapters and a wireless access point, this however is more expensive.
Lastly with EE you don't need to stick with their router so if invest in a better one that will likely help, again a more expensive but better long-term option.
by kcred2
Thanks, I'll try those options and see if it sorts - thanks for such a quick reply!
Hi @kcred2,
Thanks for joining the EE Community. Smiley Happy
Let us know how you get on after trying @Northerner's tips.
by SpyderScanner Established Contributor
If you have an android phone or tablet, instll a wifi analyser on it. You can use it to map your wifi through your house, locate dead zones and see if any other sources are using the same channels as you. It's amazing how many isps etc use a restricted set of wifi channels. (1,6,11)
Also, a lot of users automatically switch to the 5.x Ghz band because it's new and less used. The drawback is that its range and wall penetrating ability is less than 2.4. I don't know if the BB router will do it but you could try setting up a dual networks.
