by Amandaro
Please does anyone lnow how to connect my Ee smarthub to am openreach box?
Re: Please does anyone lnow how to connect my Ee smarthub to am openreach box?
You mean an OR Fibre modem? Yes, you plug it into the EE SH's red WAN port 4 using an Ethernet cable.
Are you on G.Fast BB (EE's Fibre Max)?
by Amandaro
Hi thanku, yes am on max fibre but tried all of the ports from the openreach modem and into the red ethernet port on the back of the EE router. Nothing seems to work and i end up using the fone socket to get any broadband. Still not a bad speed tho. Just wondered if anyone else has had any trouble. Cheers
Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
