by samharrison7 Investigator
Permanently slow uploads and intermittently slow downloads
Hello,
We've been having problems with our broadband speed for quite a while now: Uploads are always slow (~0.3 Mb/s) and quite frequently we get period of an hour or so when everything becomes slow or completely unusable. E.g., twice this weekend we've been unable to use the internet for about an hour.
Below are the details requested. We're on the Lancaster exchange (https://availability.samknows.com/broadband/exchange/LCLAN) and here is the link to a speed test just performed: https://www.thinkbroadband.com/speedtest/1512322424101185955
Cheers,
Sam
STATUS
Configured
Current
Line Status
UP
Link Type
Fast Path
Operation Mode
Automatic
G.992.5 (ADSL2+)
DATA RATE INFORMATION
Upstream
443 (Kbps)
Downstream
18099 (Kbps)
DEFECT/FAILURE INDICATION
Operation Data
Upstream
Downstream
Noise Margin
31.9 (dB)
6.3 (dB)
Line Attenuation
12.3 (dB)
26.5 (dB)
Indicator Name
Near End Indicator
Far End Indicator
Output Power
12.6 (dBm)
0.0 (dBm)
Fast Path FEC Correction
0
0
Interleaved Path FEC Correction
Fast Path CRC Error
0
0
Interleaved Path CRC Error
Loss Of Signal Defect
0
0
Fast Path HEC Error STR
0
423
Interleaved Path HEC Error
Error Seconds
50
0
STATISTICS
Received Data
661536 (Kbits)
Transmitted Data
359733 (Kbits)
10 REPLIES 10
Re: Permanently slow uploads and intermittently slow downloads
Your upstream sync has been pegged at 444K, the top of the ADSL Max range. It sometimes does that on ADSL2+. Ask CS if they can free it.
Thanks for your reply. Unfortunately, the response I got from CS was "there's nothing we can do about it". They suggested a router factory reset, but I'm not optimistic about that working. Any advice on how to proceed?
Hi @samharrison7,
Welcome to the EE Community.
Our technical team are the right people to help with this, unfortunately it's not always possible to remove banding.
I've been in touch with customer services again and the response was still that they can't do anything about upload speeds. Not that they can't remove the banding, just that they don't have any tools to deal with upload speeds.
From what I can gather, ADSL2+ should permit uploads of 1.4 Mb/s, but in my case is capped at 443 Kb/s. Someone somewhere should be able to remove that cap, but EE's CS don't know who. I asked if phoning BT would help, but apparently they'll just tell me to talk to EE. Any suggestions are to what I should do next? Ideally, I'd like to speak to someone with knowledge of this cap and, if it's not possible to remove it, at least give me explanation as to why.
Hi @samharrison7
I'm going to bring @XRaySpeX back into this is possible please to see if he can lend his expertise to your query.
Thank you
Richard
I've just known them to free it.
Perhaps I'm calling the wrong phone number, because as I say, the response I got was that they don't deal with upload speeds, full stop. I was phoning 0800 079 8586. Is there another number I can call to get through to someone who has knowledge of the banding/capping you talk about?
There is a so-called "email" form that you can use for BB: https://explore.ee.co.uk/broadband/email-us . Also see below in my sig.
Cheers, will give that a go.
EE Employee
