by zebbedy Contributor
Packet Loss when streaming to Twitch
I have been having on going issues with packet loss while streaming to Twitch.
The broadband team have ran numerous test on my line with no problems showing on their end.
I am getting on average 30mbps download and 5mbps upload. I am told my line is capable of 41mbps (down) but I have never reached that.
I know 5mbps is not the best upload speed hence me limiting my bitrate in OBS studio to 3500 @ 1080p 60 fps to allow some extra bandwith on the upload rather than maxing it out.
My problem is that when I am streaming my current game (Fortnite) I am receiving packet loss on the upload flickering between 1-5% sometimes higher which would not usually happen when I am streaming.
I have ran my own tests by pinging 8.8.8.8 and found that the most packet loss is coming from this IP 213.121.98.129 which google tells me is something to do with BT.
I rely heavily on my internet as I work from home streaming.
When I rang EE up they told me to basically leave and move to virgin media although this isn't available where I am yet.
I explained I would just like the problem fixed which they tell me they are not given the tools by BT to diagnose packet loss problems.
I hope you guys can help me with this. As EE has always been a reliable internet provider for myself before I recently started streaming.
Please see router stats below.
Thank you,
Zeb
STATUS
Configured Current
Line Status -- UP
Link Type -- Fast Path
Operation Mode Automatic G.993.2 (VDSL2)
DATA RATE INFORMATION
Upstream 5761 (Kbps)
Downstream 33287 (Kbps)
DEFECT/FAILURE INDICATION
Operation Data Upstream Downstream
Noise Margin 6.1 (dB) 6.1 (dB)
Line Attenuation 0.0 (dB) 24.4 (dB)
Indicator Name Near End Indicator Far End Indicator
Output Power 4.0 (dBm) 4.1 (dBm)
Fast Path FEC Correction 0 50
Interleaved Path FEC Correction -- --
Fast Path CRC Error 0 0
Interleaved Path CRC Error -- --
Loss Of Signal Defect 0 0
Fast Path HEC Error STR 0 9391
Interleaved Path HEC Error -- --
Error Seconds 729 4
STATISTICS
Received Data 1200414 (Kbits)
Transmitted Data 18524520 (Kbits)
Re: Packet Loss when streaming to Twitch
1. Try a wired speedtest, using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
2. What exchange are you connected to? If you don't know use: http://www.samknows.com/broadband/exchange_search and post the URL of your exchange page.
3. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
4. Plese do a tracert to both www.bbc.co.uk & your game server.
Thanks for replying so quickly.
I have done as requested please see below:
https://www.thinkbroadband.com/speedtest/1534717286559418455
https://availability.samknows.com/broadband/exchange/SDPCHVN
My tracert:
Tracing route to www.bbc.net.uk [212.58.244.71]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms BrightBox.ee [192.168.1.1]
2 * * * Request timed out.
3 * * 7 ms 213.121.98.129
4 92 ms 90 ms 7 ms 213.121.98.128
5 9 ms 11 ms 12 ms 87.237.20.130
6 18 ms 15 ms 18 ms bluestream-gw-b.thdo.bbc.co.uk [212.58.239.54]
7 * * * Request timed out.
8 * * * Request timed out.
9 12 ms 10 ms 9 ms ae0.er01.telhc.bbc.co.uk [132.185.254.109]
10 9 ms 9 ms 9 ms 132.185.255.148
11 11 ms 9 ms 8 ms bbc-vip116.telhc.bbc.co.uk [212.58.244.71]
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date   ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Left in JumperOther Offerings     Availability Date   Premise environmentStatus
VDSL Range A (Clean)40.2298.15.425AvailableAvailable--
VDSL Range B (Impacted)32.216.57.64.111.5AvailableAvailable--
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 5.5--4.5 to 6.5Available----
WBC ADSL 2+ Annex MUp to 5.5Up to 14.5 to 6.5Available----
ADSL MaxUp to 5.5--4.5 to 8Available----
WBC Fixed Rate2----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date07-08-2018
