by 1000green Established Contributor
Own router
My own router is only getting 1/3 of the speed i am supposed to be getting. IF i use the ee smart hub I get 300 down but if I use my r700 nightwark it gets 100down. Can anyone help. Thank jordan
Re: Own router
You don't actually know your sync speeds as they are only in the G.Fast modem. So you must be getting your speeds from speedtests.
Try a wired speedtest on both routers, using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
