by Aw6
New Member
Outages in last two hours. At least half a dozen times
Over the last 2 hours we've had at least half a dozen outages. Very frustrating. Plus tried to call EE regards to this. But the office is closed 😫
Re: Outages in last two hours. At least half a dozen times
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
