Osprey 2 it says10 devices does that mean 10 people can use at the same time
When it says that an Osprey2 can take upto 10 devices does that mean when I am on holiday with my family 10 people can use the internet through it
Solution
Accepted by James_B (EE Community Support Team)
‎21-07-2016 11:01 AM
Re: Osprey 2 it says10 devices does that mean 10 people can use at the same ti
@ChrisBuck Yes it's exactly that up to 10 devices can connect at the same time bear in mind the more connected and using it the more data it will use
Star Contributor
[ Edited ]
Yes 10 people can use but 10 devices same time,
Many Thanks
Solution
Thank you for the information, you say size of data let us say 4 maybe 5 would use SKYPE and 4 or 5 would use the internet at the same time, would that come within the 4G
ThanksChris.
Yes it would all come out of the same allowance I just obviously the more of you using it the faster the allowance will go
