by Absinthe
Openreach Ultrafast (FTTP) and EE Availability
After years of struggling with only 1Mbps over copper, Openreach have just, in the past couple of days, commissioned the infrastructure for FTTP to my area.   Putting my postcode/phone details into BT's and Zen's sales websites now lists 150 & 300Mbps options, but not for EE.
If a FTTP connection is available through Openeach, will EE offer an ultrafast service imminently?  Is the fact that I can't see an ultrafast service through EE only because the line data is a little out of date, or is there some other reason, such as exchange equipment that needs to be installed and so EE availability will be a much longer wait?
Solution
Re: Openreach Ultrafast (FTTP) and EE Availability
Yes, you can get FTTP there but not from EE who don't sell it. You can't get G.Fast, which EE does sell, there.
Any FTTC (VDSL) which you can get would be rather slow.
EE don't sell FTTP but they do G.Fast which they call Fibre Max.
What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
by Absinthe
Thanks XRaySpeX.
BT Wholesale screensnap below.  I'm about a mile from the nearest cabinet and so I think G.Fast isn't possible?  I had got the impression that for an ISP Ultrafast offering that would normally be provided as G.Fast, if over a certain distance and with fibre available, Openreach would connect FTTP for the same ISP product?  I find it had to get good information.
Solution
by Absinthe
Thanks.   It looks like it has to be Zen or BT then.
Re. VDSL, I tried to get this a couple of years ago but BT and others wouldn't install as speeds were so slow.  My only option was ADSL.
Thanks! You're welcome :)! Glad I could be of assistance.
BT should have a product called Faster BB which is for users with an expected VDSL Fibre speed < 15 Megs (they don't want to call it Infinity). Also EE might sell you their ordinary Fibre BB in such a case. Did you try EE for that?
