by Patty64 Contributor
On the bright box 2 should the power light always be green
Solution
Re: On the bright box 2 should the power light always be green
Yes, and the BB light GREEN & the Internet light GREEN flashing.
Why? Why should it not be while it is powered up?
Solution
I have 3 green lights but the power light is not on.
Then the router is faulty. Is the BB working OK? If so, it's just a minor fault; just a faulty LED.
Thank you will ring EE in the morning.
Sent from my iPad
