by ioannisa Valued Contributor
Valued Contributor
Norton Antivirus
Hi, community,
My question is quite simple or at least I think so. As I already have a subscription for Norton Premium which expires on 1/2021, purchased on my own, which options do I have for the offer via EE:
  1. Can I select the time that I will enable the offer from EE? So not to have two subscriptions in parallel overlapping.
  2. Can I extend my current personal purchase subscription via the offer from EE?
I believe that the first option will be the easiest one, but I don't know if there is a time limit from the day that I enabled EE broadband for enabling the Norton offers.
Thanks a lot.
Solution
Re: Norton Antivirus
  1. You may take up the EE/Norton offer at any time.
  2. Isn't it the same thing? Just take up the EE/Norton offer when your current subscription expires.
Solution
Valued Contributor
Thanks a lot @XRaySpeX
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
Recent solutions
