by Fredrik_Elg
New Member
No public IP
I have a weird new error message. My VPN connection to my home network no longer works and my router (ASUS) says my IP number is not a public IP number. I have never had this problem before. Has EE changed something? How do I turn off "no public IP" such that I can reach my home network again? I tried to contact EE. There seem to be no way to contact them other than by sending a letter! What is this year 1920?
Solution
Re: No public IP
With EE, & many other ISPs, you get a dynamic public IP which potentially can change dynamically with every re-sync of the line. If you are remotely addressing your LAN from outside by its last known public IP it could well have changed & the previous public IP has become a non-IP.
You should using a Dynamic DNS (DDNS) service to overcome this common behaviour.
Solution
Re: No public IP
