by Warpig Investigator
New user, got issues already, could use some advice please.
Hi all, I’ve been with EE for three days, switched from Sky because they said they could drop my bill from £102 per month with Sky to £38 with EE for pretty much the same deal. Anyway the switch over went fine and the first two days were no problem, speed was good and all was good, however today we have had several disconnections and the speed has been ridiculously slow. My sync speed with Sky has been a rock solid 66mb for several years but as you can see from the attached pics I’m getting nowhere near that from EE. Anyone have any thoughts? I was told by the person who signed me up that there was no traffic management with EE, is that correct? Thank you guys.
15 REPLIES 15
Re: New user, got issues already, could use some advice please.
There is no TM with EE. If there were your sync speed would be much higher while your throughput was low. No, it's something else.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
Thank you, @David, for removing that.
Thanks. There's some evidence of your profile being banded as a result of errors detected on your line.
You say it only started today. Has any work been done on your line or in the neighbourhood by OR engs recently?
Reboot the router & try plugging it into the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (dial 17070 Opt 2), preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Post the full router stats when plugged into test socket.
Is the issue any better?
What are all EE's speed estimates given in your MyEE for BB under Your broadband speed ?
Hi mate, these are the speeds I was quoted when I signed up
Good Morning @Warpig
Welcome to the community.
If you've just joined EE or recently moved home it takes up to ten days for the speed and stability of your broadband to settle down.
Do you use your landline? if yes, is this running ok?
Speak soon, Katie 🙂
Thanks. Have you done the test socket & QLT?
Linky don't compute! Too many https's. Corrected:
@Katie_B: The 10 day settlement period is an urban myth & does not explain why it ran OK for 2 days as fast as it was on previous ISP & on the 3rd day shot down to below the min. guaranteed speed. The DLM is running continuously, not just for 10 days.
Never use the land line but just checked and it’s fine.
Sent from my iPad
Hi Katie, thank you for your reply, I agree 100% with you, the 10 day period is a nonsense. As I said originally I’ve been synced at 66mb for several years with Sky and only changed because EE said they could do the same deal for a lot less money. I don’t understand how I’ve got the same wires from the same exchange yet I’ve gone from 66 to 12mb which it is currently connected at.
Regards Brian J.
Sent from my iPad
Hi @Warpig
Thanks for coming back to me.
Have you spoke with our technical team who can look at this further?
Katie 🙂
Speaking to them now 🙂
Sent from my iPad
@Warpig: It was I who said the 10 day period is a nonsense.
The DLM system has put you on a banded profile in response to past detected errors on your line. You normally need to give the DLM time to relent & remove any banding.
However in this case your sync speed is well below EE's Min. Guaranteed Speed & BT's Handback Threshold; in fact it is only about a quarter of them. When speaking to EE you should emphasis this & insist that they pull their fingers out & fix it ASAP. Give them no more than a week or you'll leave FoC.
