by Iceash Investigator
New to Fibre
Hi Everyone,
I've been a fibre customer since the 9th of Sept.  My active speed tests started at 60mbs with the Router shower a 65mbs connection.  I'm now achieving 56mbs on live checks. Could this be contention or could something else be a miss?
Looking forward to your advice and comments.
Thanks,
Ash
16 REPLIES 16
Re: New to Fibre
Or could it be insignificant?
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
Re: New to Fibre
Thanks for the tips I shall try tonight. The Speedtest are carried out wired.
Re: New to Fibre
Let us know how you get on @Iceash
Leanne 🙂
Re: New to Fibre
I shall indeed 😊
Re: New to Fibre
Okay, so here goes
DSL uptime:0 Days, 22 Hours, 13 Mins, 14 Secs
Data rate:14.30 Mbps / 63.84 Mbps
Maximum data rate:14.42 Mbps / 64.18 Mbps
Noise margin (up/down):6.1 / 6.1
Line attenuation (up/down):18.3 / 15.9
Signal attenuation (up/down):18.3 / 15.9
Data sent / received:1.2 GB / 4.6 GB
Broadband username:PRODUCTIONHQNUN372728733@fs
2.4 GHz wireless network name:Icelight
2.4 GHz wireless channel:Smart (Channel 6)
5 GHz wireless network name:5GHz-EE-Hub-5LFo
5 GHz wireless channel:Smart (Channel 40)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address:64:CC:22:EC:62:B2
Software variant:-
Boot loader:0.0.3-EE (Mon Dec 4 17:32:53 2017)
Speed Test Result
   History    Test Again
DOWNLOAD
48.5 Mbps
tbbx1 48.4 Mbps
bursting to 56.0 Mbps
UPLOAD
11.4 Mbps
bursting to 12.4 Mbps
Your Latency: 25 ms Analysis SSL
Ultra HD streams 4K should work
Re: New to Fibre
What are those long columns of figures in your post?
& now for the BT Broadband Availability Checker please?
Re: New to Fibre
Re: New to Fibre
Made visible:
@Iceash wrote:
They’re from the live speed test
Exchange SAINT OSYTH is served by Cabinet 7
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date
ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
Left in JumperObserved SpeedsVDSLADSLOther Offerings
Availability Date
Premise environmentStatus
VDSL Range A (Clean) 80 66.4 20 19 60 Available -- --
VDSL Range B (Impacted) 80 64.4 20 19 58.3 Available -- --
FTTP on Demand 330 30 -- Available -- --
WBC ADSL 2+ Up to 3 -- 2.5 to 6.5 Available -- Yes
ADSL Max Up to 3 -- 2 to 5.5 Available -- --
WBC Fixed Rate 1 -- -- Available -- Yes
Fixed Rate 1 -- -- Available -- --
Max Observed Downstream Speed (Mbps) 64.36 3.76
Max Upstream Observed Speed (Mbps) 14.81 0.85
Observed Date 2019-10-05 2019-08-05
VDSL Multicast -- -- -- Available -- --
ADSL Multicast -- -- -- Available -- --
Bridge Tap N
VRI N
NTEFaceplate N
Last Test Date 27-09-2019
FTTP is not available.
Re: New to Fibre
Re: New to Fibre
Re: New to Fibre
Why won't my copy page image show ☹️
Re: New to Fibre
How can I turn the text black?
Re: New to Fibre
With difficulty!
Re: New to Fibre
You are awesome 😎
now what does all this mean.
Download Speed (Mbps): 55.54
Upload Speed (Mbps) : 12.00
Ping Latency (ms): 17
Re: New to Fibre
You're getting 64 Meg Sync speed at the bottom of your expected range.
Reboot the router & try plugging it into the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (dial 17070 Opt 2), preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Post the full router stats & TBB Speedtest link. when plugged into test socket.
Is the issue any better?
Re: New to Fibre
Nope, still the same, also spoke to EE, as I’m above the minimum speed of 53 they see no problems
