by heidilara97 Investigator
New customer, smart hub set up
I am unable to set up. I keep getting aqua lights. Its all set up correctly and I've had my activation text but I have no internet. Any help?
6 REPLIES 6
Re: New customer, smart hub set up
You should have steady aqua lights. Are they flashing?
What does it say after you log into the router:
  • For a BrightBox: in the Internet section on the initial Status page or
  • For a Smart Hub: on the Advanced Settings / Broadband / Internet page?
Obscure your names & numbers in the BB Username but post the 1st 2 parts of the IP addy. This will tell us at which stage EE have got to.
Does the phone work? Do you get a dial tone? Does it announce your correct no. when you dial 1470 17070?
They're flashing lights not steady.
I don't have a phone so I cannot check the dial tone.
Does the BB Username say readytoconnect@fs or your own Username?
I suggest you buy a cheap corded handset, which can often be had for about £5, & making the occasional call to "wet" the line. Also having a handset is invaluable for helping diagnose Broadband faults. This could well save you the cost (about £130) of an engineer call-out finding the fault lay within your home.
It says readytoconnect... Okay I will do. Thank you x
Hello.. there's no dial tone and we've taken the faceplate off and that didn't work either
Hi @heidilara97,
Please get in touch with Customer Care so we can make sure your broadband has been connected and help you get up and running.
