by BigIFFY Investigator
New EE Customer paying for 76Mbs.... Not even close.
Have EE/OpenReach forgot to flick a switch .??
Will it speed up after 7 days "Settling Period" .??
by Star Contributor
Star Contributor
Re: New EE Customer paying for 76Mbs.... Not even close.
Hi @BigIFFY
Welcome to the EE Community,
It's up to 76 Mbps it depends on the quality of your line and the distance from your local cabinet to your house.
Thank you for the welcome. Smiley Happy
According to the engineer, should be getting 60+ Mbps no problem.
In the Modem Log it says Max data rate = 41.96Mbps
What upgrade have you done? If it was to Fibre Plus and OR had forgotten to flick a switch you'd still be syncing at the cap  40 Meg
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
To phone EE: The local rate landline number 0207 362 0200 or Freephone 0800 079 8586 - Option 1 for Mobiles; Option 2 for 4G WiFi; Option 3 for Home Broadband & EE TV.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC = 2014: EE 20 Meg WBC
https://www.thinkbroadband.com/_assets/speedtest/button/1547158496101932655-mini.png
Product name,EE Smart Hub
Serial number,+EEH001+1843007485
Firmware version,v0.00.24.06190-EE (Tue Jun 19 17:25:19 2018)
Board version,01
Data sent / received,155.7 MB / 559.0 MB
DSL uptime,1 days 5 Hours 13 Mins 36 Secs
Data rate,10.01 Mbps/36.65 Mbps
Maximum Data rate,10.0 Mbps/42.0 Mbps
Noise margin (up/down),6.1/6.2
Line attenuation (up/down),19.4/15.6
Signal attenuation (up/down),19.2/15.0
Broadband username,PRODUCTIONHQNUN391814499@fs
2.4 GHz wireless network name,EE-Hub-Mw7j
2.4 GHz wireless channel,Smart (Channel 6)
5 GHz wireless network name,EE-Hub-Mw7j
5 GHz wireless channel,Smart (Channel 48)
Wireless Security,WPA
Wireless mode,Mode 1
Firewall,Default
MAC address,
Software variant,-
Boot loader, 0.0.3-EE (Mon Dec 4 17:32:53 2017)
Connection status,Connected
Ethernet / Fibre / ADSL,Fibre
Ethernet WAN,Off
Downstream sync speed,36.65 Mbps
Upstream sync speed,10.01 Mbps
Network uptime,1 days 6 Hours 16 Mins 16 Secs
System uptime,1 days 6 Hours 19 Mins 24 Secs
Thanks & now the BT Broadband Availability Checker ?
Telephone Number 01472 on Exchange HEALING is served by Cabinet 6
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High Low High Low
VDSL Range A (Clean) 79.4 57.7 20 18.7 52.3 Available Available --
VDSL Range B (Impacted) 77.3 54.1 20 16.9 46.3 Available Available --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 5.5 -- 4 to 6.5 Available -- --
WBC ADSL 2+ Annex M Up to 5.5 Up to 1 4 to 6.5 Available -- --
ADSL Max Up to 3.5 -- 1.5 to 5.5 Available -- --
WBC Fixed Rate 1 -- -- Available -- --
Observed Speeds
VDSL
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- --
ADSL Multicast -- -- -- Available -- --
Premise environment
Status
Bridge Tap U
VRI --
NTEFaceplate --
Last Test Date --
Your sync speed is below the Handback Threshold.
Reboot the router & try plugging it into the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (dial 17070 Opt 2), preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Post the full router stats  when plugged into test socket.
Is the issue any better?
