Highlighted
Network Proxy Setting Error
So this happened last night. I suddenly lost my Internet Connection and I even confirmed it with the lights on the Brightbox.
Also, I was seeing an exclaimation mark on the Internet symbol in my PC.  I ran the troubleshooter and it showed up with "Unable to Detect Proxy Servers".
Now I don't know much about computers but I sure need my connection to work fine.
Can anyone tell me what might have caused this so that I will know if it happens again?
Highlighted
by Investigator
Solution
Re: Network Proxy Setting Error
Hey,
This is probably one of the most annoying proxy errors that can occur. According to many people, they are unable to save or change their proxy settings.
Since @XRaySpeX already suggested to explain your issue more. I'll suggest you follow his command. However, if you want to try out to fix it up yourselves, maybe you can try the following link to fix Windows Could Not Automatically Detect Network’s Proxy Settings. If that doesn't work, try this thread from Microsoft's Forum.
https://validedge.com/windows-not-automatically-detect-networks-proxy-settings/
https://answers.microsoft.com/en-us/windows/forum/windows_7-networking/windows-could-not-automatical...
Highlighted
@alexbach: Welcome to EE's Home Broadband Forum.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
Highlighted
by Investigator
Solution
Hey,
Highlighted
Recent solutions
