by AlfieB94 Established Contributor
Network Problems in the Yate, South Glos area
Ive been having problems recently with my EE Fibre Broadband service / Brightbox 2 router whick keeps dropping connections.
When I check the Network status it comes back with the reason being there is a fault in my area and BT are working to fix it.
A BT engineer came and checked my setup at home back at the end of May and said that that was OK but the problem still happens.
Has anyone got any thoughts on my problem ??
71 REPLIES 71
Re: Network Problems in the Yate, South Glos area
Good Morning @AlfieB94
Welcome to the community.
I'm sorry to hear you're having trouble with your broadband, how long has this been happening for?
Were you given an estimated timescale for the fault in your area being fixed?
Hope to hear back from you soon.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
4. What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
Hi there
To be honest I’ve been having problems with my broadband /internet connection since around late May. During that time I lost my router connection for a week. EE sent a BT engineer to my property to check my wiring to the master BT socket. This proved OK but he suggested that I contact EE to arrange a new router to be sent. I did this and was told that there was nothing wrong with the router it just need some changes. I had to make these changes whilst the EE technician told me what to do. This I did but in the end it did not work so we put the router back to how it was originally set. Since then my Broadband / WIFI connection hasn’t worked properly. I’ve contacted EE on many occasions to report poor or no connections.
I’ve used the EE Network Status Checker on numerous occasions and the latest this afternoon tells me that they are still working on a fault. I’ve attached a screen shot of it. I’ve also attached screen shots taken from my PC’s Network Sharing Centre. This shows my WiFi status which you can see is only showing 2 bars and also something new called a Local Area Connection-16 Status which I haven’t got a clue what it is because its only just appeared in the past week.
EE sent me a new router and that still gives the same results.
I really don’t know what work BT are carrying out but all I know is that ever since they commenced it I’ve had poor connections.
I don’t get any problems with my landline.
Regards
AlfieB
Sent from Mail for Windows 10
16-07-2018 Screenshot (4).pngScreenshot (19).pngEE Network Status Checker today
EE Employee
Hi @AlfieB94
The network status checker does not hold any information for broadband issues.
If you follow the steps that @XRaySpeX has provided, he may be able to diagnose an issue.
Many thanks,
Lee
There are no changes you ever need to make to a router just to get the BB working. The only changes you would need to make would be for your own local networking purposes & EE wouldn't be concerned in that.
I'm afraid I'm unable to comment further on your issue w/out knowing the characteristics of your line from the info I requested rather than screenshots of the state of your PC.
Thanks, @Lee_H, I thought it didn't but was waiting to see OP's image to deny it as I couldn't be sure what status checker the OP was using.
So the whole business of BT working on a fault in the area has nowt to do with this.
I wish someone would tell EE CS to stop trying to improve users' WiFi when it is the basic BB that is not working.
Hi there thank you for your support. To be honest Ive not looked at your suggestions yet, This is because I'm still trying to get things clear in my head, because I'm even more confused now as to where or what my problem is.
I've attached two screen shots from my PC Control Panel Network and Sharing Centre. One shows my wifi and the other is something new which has just apperared in the last couple of days. I dont even know what its for?
If you look at the wifi image you will see that the signal seem yo be very week and this evening I'm finding that wifi appears to keep disconnecting. EE Customer Service dont seem to be able to give me an answer when it will be sorted. At the moment their only suggestion is to send another BT engineer alomg to my home. Well they did that a few weeks ago and they said there was noyjing wrong with their set up.
Best wishes
Screenshot (20).pngWiFi StatusScreenshot (21).png??? What is this??
Yes, it's confirmed that that network status report relates only to EE's mobile network & that EE, not BT, is looking into it. So you can forget that.
Looks like you have your PC connected to the BB (& the Net) by both Ethernet & WiFi. Not a good idea!
What does Control Panel\Network and Internet\Network Connections show? Is MIKEB*****0115 your PC's Computer Name?
What does the command ipconfig /all show, obscuring your names & MACs?
However this is a secondary issue which we could look into later once we have investigated your BB connection. So I would appreciate seeing all the data I requested.
By going down your own route you are not clearing your head but confusing it if you can't interpret what you see. Please give us what we ask for & leave the interpretation to us.
I’ve already done a Wi-Fi speed test so that should do. I’ll send that first?
Also noted your comments re posts so I’ll give it a go and see how we get on.
Probably easier to do it a section at a time?
Regards
Sent from my iPhone
FW: Your EE Community subscription
Dear XRaySpeX
Just to let you know I’ve started going through your original email gathering as much information as you asked for. The only thing I can’t do at the moment is to do a test using the ethernet cable into my Brightbox 2. I cant use my PC as its too heavy for me to get it down near the router, so I need to get a laptop.
The other problem is that I didn’t have a clue on how copy the other information but at the moment I’ve taken Screen shots of every thing I’ve looked at. TBH I could probably send it to you by email which would be easier for me. Perhaps you’d let me know what I should do, I can give you my email address .
In your latest post you mentioned about me being connected to both Ethernet & WIFI and you say not a good thing. Sorry just cant see that,
The other thing you asked is what is my PC name.?? Its MIKEBIDWELL. Ive got a screen shot of that as well??
Best wishes
AlfieB94
Sent: 28 July 2018 08:38
To: xxxxxxxxxxxxxx
Subject: Your EE Community subscription
My EE
Shop
Why EE
Hello AlfieB94,
XRaySpeX posted a new reply in Broadband & home phone.
Read it here: Re: Network Problems in the Yate, South Glos area
Reply | Mark as the solution | Mark as helpful
The EE Community Team
EE Community | Log into My EE | Official EE Help
Manage your EE Community emails or unsubscribe
If you can't do a wired speedtest than at least do a wireless one.
Sorry, this is a public discussion group. No dialogue is carried out via private email. but only in these posts on the forums (they are not emails).
You could copy & paste the info to your posts or you could insert images.
Brightbox image 1A.pngBrightbox image 1B.pngBrightbox image 2A.pngBrightbox image 2B.pngHereBrightbox Image 3.png
Here are the last 3 images I think you requested, Hopefully Ive got them all done??Broadband Availability Checker.pngBroadband Speed Test reults using WiFi.pngUK Exchange Search.png
Sorry, that is not the correct router stats page.
Please login to your Brightbox and navigate carefully to Advanced Settings/ Accept/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
I posted 5 images but it appears 3 didn’t send.
So I’ll post the 3 that failed and fingers crossed you hopefully will get
what you want.
Regards
Thanks. Can't you just post them by copy & paste? The BT Checker image came out perfectly.
hopefully this is the information you requestedDSL Status.pngSystem uptime.png
