by Fastsuper
NTP synchronization failure
My Smart Hub cannot get the right time (sets 01 January after restarting) and then does not get internet connection at all (everything else seems fine). Apparently it is a repeated issue related to the NTP server, but any hint on how to fix it or let EE know to fix it? Thanks.
Re: NTP synchronization failure
Are there failure events about the NTP in the System Log?
by Fastsuper
Yes, I get in the log sequences of NTP synchronization start and then NTP synchronization failure after a few seconds.
