by NRHeeacount Investigator
My wifi is working but my ethernet ports do not work
I have tryed resetting the modem/ router and using each ethernet port and even using different devices and ethernet cables. Please help
Solution
Re: My wifi is working but my ethernet ports do not work
Nevermind i used 2 different faulty wires to check the internet and now i replaced them. Its working now
10 REPLIES 10
What devices are you connecting to the Ethernet ports? You are using the LAN ports & not the WAN 1?
I am using the lan ports. I am trying to connevt my pc. It was working before but it all of a sudden stopped working. Btw i have the brightbox 2
Could be faulty Ethernet card on PC. Are you trying more than 1 PC?
I tried on my laptop and pc but the same thing keeps popping up ;
Ethernet doesn't have a valid ip configuration
What does that mean & where do you see it?
What does ipconfig /all show under the Ethernet section?
Here is a link to a picture of what it says.
Yes, the PC doesn't think it's connected to a router.
What does the router show under Currently Connected Devices? Also what does it say in the Internet section? Obscure your names in the BB Username but post the 1st 2 parts of the IP addy.
Solution
EE Employee
That's great news @NRHeeaccount
Happy to hear it's all sorted!
Thanks for popping back to let us know.
Thanks - Karen. Smiley Happy
