by ronswold Established Contributor
My wifi connection is poor
The wifi connection from my laptop,phone and tablet keeps dropping out for several minutes at a time and my equipment switches to 4G using up my mobile data allowance
The up and down arrows disappear from my devices,I get "time out" messages frequently, I get "your connection is slow" messages
EE have sent me emails over the last 6 months saying there is a problem close to my property or essential maintenance is being carried out or routine maintenance is being carried out and later "the problem is solved"
A few days later more emails and more problems
ronswold
12 REPLIES 12
Re: My wifi connection is poor
To what WiFi network? Your home BB or hotspots in general?
About what? Problem with what?
To my home broadband
Sent from my Samsung device
@ronswold: Welcome to EE's Home Broadband Forum.
1. Post your full router stats. For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page. Full router stats are key to any speed & connection issues.
2. Try both a wired & wireless speedtest here http://www.thinkbroadband.com/speedtest.html and copy to here just the "Link to this result:" link.
Yes I would like some help so i will gather the information you need and send it for you to look at
Sent from my Samsung Galaxy smartphone.
You sure these emails are about Home Broadband not just about your home? Never heard of such msgs about BB but such msgs are sent out by EE about state of mobile network in your vicinity. Do you have EE mobile/SIM?
I'm not saying they are about home broadband cos they are not specific so I don't know what the EE engineers are doing
Someone is often peering into the green junction box down the road and my next door neighbour complains often about his broadband connection
Just telling you what's happening around my home
And yes I do have EE mobile
by Star Contributor
Star Contributor
Last year you posted a similar problem about poor connections. Did you sort it out then? Are you still using a Technicolor router?
No it didn't get sorted as I was taken ill so I deferred it  and I'm still using the Technicolor router
by Star Contributor
Star Contributor
So the variables in this case appear to be long term issues with the line to your house, and a non-standard router.  I'd say the first step is to do a quiet line test to see if there is noise on the line. Then escalate to customer services to test the line and get Openreach to sort out the long term issues with the line and broadband.  Once that is sorted, then test on ethernet to router. If that is good / OK, then test the wifi.   The wifi is the last thing to test.
Still working on this problem
Trying to find out how to contact EE
Seems that all paths lead to the EE Community and no direct links to EE themselves where i can get something done
Last week more emails from EE about problems reported close to my address and later "ROUTINE" maintenance "now complete"
Don't know what they are up to and latest error message says "no Internet connection " and today i could not complete an online purchase
Looks like i shall be moving soon but no good going to BT cos they and EE are in the same clique now!
Well, if you could get the info. I asked for in post 4 about a month ago we might get a bit further forward.
Hi @ronswold,
Welcome back to the community.
If you can provide the information @XRaySpeX has asked for I'm sure he'll be happy to help you locate the cause of the issue.
Alternatively, you can find contact details for our customer service team on the get in touch page. Our technical team will be able to look into this for you.
