by Nigelwilliams11
My router constantly needs restarting
Ee router is always chasing
by Nigelwilliams11
My router needs rebooting
My EE router chases on s daily basis. Restarting it gets it running again for a while. Is there an upgrade available?
Re: My router constantly needs restarting
@Nigelwilliams11 : Welcome to EE's Home Broadband Forum.
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
