by RitaA
My internet today no good
My internet today sinal no good
Re: My internet today no good
Hi @RitaA
Can you confirm if your problem is with your Home broadband or mobile broadband?
How is it no good?
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
